Transient Error
Old   September 19, 2008, 02:43
Default Transient Error
S. KRISHNAN
While Running a Transient Simulation, the following error message reported. the problem is of a rotating domain.
ERROR #002100012 has occurred in subroutine VolSec. Message: A negative ELEMENT volume has been detected. This is a fatal error and execution will be terminated. The location of the first negative volume is reported below. Volume :-0.3418E-11 Location : ( 0.11619E-01, 0.33515E-04, -0.68488E-02) Can anybody suggest a solution for this?
sathyan +----------------------------------------------------------
Old   September 19, 2008, 07:52
Default Re: Transient Error
sanjay pawar
I think u should check ur mesh. "a negative element volume" error was related to improper meshing.
Old   October 2, 2008, 07:03
rohit
there is a negative volume in your mesh and the coordinates are also given, please check it.
and check te angular velocity given and time step if you are doing mesh deformation
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
OpenFOAM install on Ubuntu Natty 11.04 bkubicek OpenFOAM 13 May 26, 2011 05:48
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
