September 19, 2008, 08:56 |
close clearance rotor
hello all i m working on CFD modeling of close clearance rotor.The gap is 2 mm. should i use MRF? i think gap is too small so currently i m working with moving single domain only. what to do?
September 21, 2008, 18:45 |
Re: close clearance rotor
You have not explained what you are trying to do. How big is the rotor? What type of rotor is it? What is the Re of the impeller? But at first glance I think a MRF approach would be fine, you will just have to be careful to generate a good mesh to capture the geometry. Glenn Horrocks |
September 22, 2008, 02:09 |
thanks Glenn The geometry is having outer vessel (Length 0.4 m and diameter 0.05m) with a close clarance impeller having a rotor of length 0.35 m (nearly same as that of outer vessel)and three blades mounted on rotor (vane type impeller)having same length as that of rotor.the geomerty is somewhat similar to agitated thin film evaporator.
i want to study the flow pattern in my geometry but due to very low gap (< 2 mm) in outer wall of vessel and inner rotor, i m unable to apply moving refernece frame (MRF). currently i m applying whole domain to rotate with outer vessel wall as counter rotating wall. Is this right? if not can u suggest how to model such close clearance vessel.( note that clearance is not at the bottom its at the outer wall and inner agitator). waiting for your response, thanks a lot in advance sanjay |
September 22, 2008, 18:36 |
You can model this with MRF with an interface between the rotor and the housing but meshing is difficult. If you can model it as a fully rotating section with the housing counter-rotating that is much better. Glenn Horrocks |
September 23, 2008, 00:07 |
hello Glenn thank a lot
CFD analysis on wind turbine rotor | Ken (Wind Turbine CFD Super Rookie) | Main CFD Forum | 45 | February 9, 2016 14:07 |
Wave Rotor simulation | popezmark | OpenFOAM | 8 | February 4, 2014 18:00 |
Frozen Rotor Model CFX | windsim | CFX | 13 | January 5, 2012 13:25 |
CFD of a helicopter rotor, solidworks? Ansys? | Elipsfire | Main CFD Forum | 0 | February 21, 2010 04:56 |
Brake Rotor Thermal Calculation in STAR-CD- Urgent | ps | Siemens | 3 | June 27, 2006 04:18 |
