Perl script for intialisation
Old   September 5, 2008, 04:43
Default Perl script for intialisation
pratik mehta
I am in need of a perl script for my CFX run , i need a script which does the first solver run with steady state for 200 iteration and later transient for specifed number of total timesteps and Max coefficent loop of 3 per timesteps. here in my script I have made two .def files one steady and another one unsteady , all I need this script to run the steady file and later run unsteady with initialization with the result file of steady state
I have my script as shown but it doesnt work at all , could anyone please tell me where are the mistakes ?
************************************************** ** %run1= (NAME => "run1", INIT => "");
%run2= (NAME => "run2", INIT => "run_001.res");
# Define a list of definition files to run @runList = ("\%run1", "\%run2");
foreach $run (@runList) {
if (!defined($run->{NAME})) {
print "Found run without a name.\n";
$errors = 1; }
if (!defined($run->{INIT})) {
print "No initial file found for " . $run->{NAME} . ".\n";
$errors = 1; } }
#loop over the list foreach $run (@runList) { $name = $run->{NAME}; $initFile = $run->{INIT};
#Open the solver to accept some CCL from STDIN open(SOLVER,"|cfx5solve -def steady.def -name $name $initCmd -part 2 -start-method \"MPICH2 Local Parallel for Windows\" ");
} # end of loop
Thank you in advance for your kind response
Old   September 9, 2008, 11:24
Default Re: Perl script for intialisation
underGroundMan
Let me make life easier for you. Run a steady state flow and then initialise your unsteady flow with steady state results. Easy peasy
Old   September 10, 2008, 03:09
pratik mehta
hello,
Thats what I want to do using the script since I have many such cases to run for different geometries, In all I have 8 definition file and each one needs this process of steady state run and later transient run.
My entire goal is to do this by perl script , So I need some help in making the script which will do the things as mentioned
thanks for your kind reply
[ICEM] Script: problems with face names Maweil ANSYS Meshing & Geometry 3 April 16, 2019 09:10
Using Perl script and power Syntax in CFX-Pre omidiut CFX 3 October 18, 2011 06:10
perl script error (looping) amazdeh Main CFD Forum 0 September 11, 2009 12:47
Solver Control via .pre file with Perl script ahlo CFX 1 March 7, 2008 12:33
Time-steps via Perl in CCL Rui CFX 5 March 29, 2004 00:47
