ICEM Mesh Matching
Old   September 10, 2008, 20:15
Default ICEM Mesh Matching
Tristan
I'm trying to create a mesh in ICEM for an intake manifold and an attached port. I meshed the port fluid volume first by itself because meshing everything together produced lousy inflation layers inside the port. Is there a way I can now mesh the manifold fluid volume so that it matches the port mesh at the interface between the two?
Old   September 23, 2008, 09:35
Default Re: ICEM Mesh Matching
rohit
Dear Tristan,
You can simply take the surface elements of the port fluid interface and select the option "Use Existing Mesh parts" in compute mesh tab and perform the tetra meshing for the manifold fluid volume. this will generate a tetra mesh which has same elements on the interface as of port interface mesh.
Old   September 24, 2008, 13:15
Tristan
Rohit,
Thanks for the advice. I tried that initially but I kept running out of memory. It did work on a small test case though.
Tristan
Old   October 8, 2008, 00:54
Manith
Hi Tristan,
Maintain same size surface & curve for both the surfaces.
you can get same mesh distribution.
or
even if their is any variation, u can create an Interface Boundary condition is CFX-PRE. This ensures that values on one surface is almost same as on the other surface.
Manith
[Commercial meshers] icem fluent mesh with cyclic boundary condition jiejie OpenFOAM Meshing & Mesh Conversion 2 February 24, 2020 03:34
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
ICEM Edit Mesh blackbody ANSYS Meshing & Geometry 3 March 8, 2010 02:49
ICEM clustering of mesh points and multiple edges webhaw CFX 4 July 25, 2007 16:29
