Particle Tracking - Can't define water particles |
September 29, 2008, 08:05 |
Hi-
Using ANSYS-CFX, I am trying to simulate Spray using Particle Tracking. The problem involves air flow in a pipe, water is injected through an injector when the air is half-way through the pipe. In the fluids list, i select both water and air. Then when i check the box - particle tracking, i cannot pick water from the particle list. Am i doing something wrong here? Please help asap. CFDLife |
October 2, 2008, 06:28 |
Re: Particle Tracking - Can't define water particl
Dear CFDLife,
when you are using the particle tracking, you should not select the water in the fluid list..then you can see water in your partical tracking list. rohit |
October 3, 2008, 06:12 |
Dear rahul if we select water in fluid list then also we have water in particle tracking list. so how to go further?
Number density tracking rather than particle tracking | Rebecca | Main CFD Forum | 2 | April 23, 2009 12:52 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
how to define particle mass fraction in the subrou | Neser25 | CFX | 1 | October 6, 2005 09:20 |
Particle Tracking | Pravir Kumar Rai | FLUENT | 2 | January 30, 2003 19:16 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 07:10 |
