CFD Analysis of pump
Old   October 5, 2008, 23:23
Default CFD Analysis of pump
remith
hello can anyone help me in analysis of pump using CFD? I dont know how to use the effect of rotation in CFD. which mesh is better tetra or hexa? The software is ANSYS CFX.
Old   October 5, 2008, 23:24
Default Re: CFD Analysis of pump *NM*
remith
Old   October 6, 2008, 03:36
Amit Roghs
Hexa Mesh is best and to give rotation give the impeller
domain as rotating.
Old   October 6, 2008, 06:42
rohit
Dear Remith,
Always hexa mesh is better than the tetra mesh, please go through the tutorial file "Flow in an Axial Rotor/Stator" for defining rotation
Old   October 6, 2008, 07:00
Rogerio Fernandes Brito
Tetrahedron mesh is much more easy to build and for the first approaching, use this type of grid.
Old   October 6, 2008, 07:07
rohit
i agree with Rogerio,
for your initial calculations you can go ahead with tetra mesh, but finally if you are looking for accuracy go with hexa mesh
Old   October 6, 2008, 07:19
Even so for a good accuracy, if you use tetra with a good number of elements, it is not to be wondered at you will find a good result. BUT, itīs good to make a study of the independence of the grid.
Old   October 6, 2008, 07:57
rohit
if you are looking at drag or seperation then it does not make sense to run a case with tetra cell. even if you have good number of cells in your domain.
Future CFD Research Jas Main CFD Forum 10 March 30, 2013 12:26
analysis of pump flow in ANSYS prakash CFX 3 September 10, 2008 06:13
Flow analysis of regenerative PUMP venky FLUENT 0 March 20, 2006 22:05
CFD Package for Water Pump Design !!! John Sheng Main CFD Forum 7 September 4, 2001 09:29
CFD Analysis on Shock/Boundary Layer Interacton'-HELP Mujahid S. Suhaeb Main CFD Forum 8 December 1, 1999 17:14
