Home > Forums > CFX
Two ways for Gradient: two different worlds?
Old   October 4, 2008, 09:35
Default Two ways for Gradient: two different worlds?
frank
hi all,
I add an additional variable named 'myav' for a 3D subdomain with poisson equation to my model in CFX 10.0. I want to get the Gradient of 'myav', so i have done the following in user CEL subroutine and the core part is
CALL USER_GETVAR('myfluid.myav.Gradient',...)
and set the returned value to another additional variable named 'myavGrad'.This method can be found in http://www.cfd-online.com/Forum/cfx_...cgi?read=21267 given by opaque. Everything goes well.
But in CFX-POST, There is a variable named 'myav.Gradient' given by the system. So the two methods should give out the same gradient distribution, but they do not. The distribution by system is right and gradient by fortran subroutine is irrational.
Why?
I check the help document for USER_GETVAR. There is a paragraph about 'LOCALE',Gradient for 'Vertices', 'ELement averaged' and 'face averaged'. Is it where the difference comes from? How to select the LOCALE in USER_GETVAR?
Any suggestion will be appreciated.
frank
Old   October 4, 2008, 21:46
Default Re: Two ways for Gradient: two different worlds?
frank
Sorry,they are the same. The difference come from me!
Old   October 6, 2008, 10:46
CycLone
Hi Frank,
Version 11 introduced CEL functions you can use in the solver to return gradients; you no longer need to use FORTRAN for this. The gradient of "myav" in the X direction is simply myav.Gradient X.
To get the gradients, create a second AV of type vector, "myav gradient" and set the X, Y, and Z components of the vecotr equal to myav.Gradient X, myav.Gradient Y, and myav.Gradient Z respectively.
-CycLone
Thread Tools
Trackbacks are On
Ways to find Mass transfer coefficient using CFD? tuks_123 CFX 10 April 15, 2011 11:20
Two grid discretization ways songpen1985 FLUENT 0 January 14, 2010 09:45
simulate flat air passage ways Fonss OpenFOAM Running, Solving & CFD 2 July 21, 2009 23:54
Shock Ways saba Main CFD Forum 4 November 6, 2002 22:41
Shock Ways saba FLUENT 2 October 31, 2002 01:33
