CFD Analysis of pump
hello can anyone help me in analysis of pump using CFD? I dont know how to use the effect of rotation in CFD. which mesh is better tetra or hexa? The software is ANSYS CFX.
Re: CFD Analysis of pump *NM*
Hexa Mesh is best and to give rotation give the impeller domain as rotating. |
Dear Remith,
Always hexa mesh is better than the tetra mesh, please go through the tutorial file "Flow in an Axial Rotor/Stator" for defining rotation |
Tetrahedron mesh is much more easy to build and for the first approaching, use this type of grid.
i agree with Rogerio,
for your initial calculations you can go ahead with tetra mesh, but finally if you are looking for accuracy go with hexa mesh |
Even so for a good accuracy, if you use tetra with a good number of elements, it is not to be wondered at you will find a good result. BUT, itīs good to make a study of the independence of the grid.
if you are looking at drag or seperation then it does not make sense to run a case with tetra cell. even if you have good number of cells in your domain.
| All times are GMT -4. The time now is 15:08. |
