Wall function modification
Old   October 17, 2008, 11:01
Default Wall function modification
tommy
In the case of specific problem, such as natural convective flows, probably a modification of the standard wall functions could improve the predictions. Does anyone know if it is possible to modify the wall functions giving, for example, non linear relationships between the constant of the velocity profile and the variables such as y+ or wall shear stress ?
Thanks you in advance
Old   October 19, 2008, 19:13
Default Re: Wall function modification
The wall function approach has been extensively validated and fiddling with the values of constants is not a good idea. If you need to fiddle with wall function constants then you should abandon wall functions. If the default wall functions are not proving accurate I recommend not using wall functions but integrating to the wall (ie y+=1).
Old   October 20, 2008, 06:23
tommy
I don't completely agree with you in the sence that the standard wall functions have been formulated in equilibrium forced convective boundary layers. In recirculating flows or when the natural convection plays a significative role, the departure from the standard wall functions is significative. In these case some authors provided new wall functions and their predictions are in well agreement with the corresponding experimental data.
Old   October 20, 2008, 21:33
You won't make standard wall functions accurate in recirculating or natural convection flows by fiddling with the model constants! The entire approach is not applicable so that is why you need to abandon wall functions and integrate to the wall.
Old   October 22, 2008, 09:40
pratik mehta
Glenn is absolutely right , if u at all want to use wall function then forget about resolving boundary layer or the thermal boundary layer as in your case (assuming u r using CFX solver ) . All I could suggest is that first of all change the turbulence model to SST and use automatic wall function only if you mesh have a yplus betweeb 0 to 10 , though I would reccomend to you to have yplus between 0 to 1 but it depends on many factors of your simulation goal. Ya modification of wall function is not easy just by some number for sure .
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
