Can I use .gtm mesh in Fluent?
Old   October 22, 2008, 08:19
Default Can I use .gtm mesh in Fluent?
sandy
If I have .gtm mesh made by CFX-mesh. Can I load it in Fluent and do the calculation? Thanks.
Old   October 22, 2008, 10:01
Default Re: Can I use .gtm mesh in Fluent?
Rogerio Fernandes Brito
If you have ICEM CFD software there, i guess you can export the msh mesh to Fluent. I can try to do it for u. Send me the file ou send it to http://rapidshare.de/.
Old   October 22, 2008, 10:31
CycLone
No need. If you created the GTM in version 11 of the ANSYS Meshing app, just make sure you options are set to save the mesh to the cmdb file. From the Tools menu of the meshing app you can export a Fluent .msh file.
Note that FLUENT can also read CFX .def and .res files, but this requires you to have set the model up in CFX-Pre.
-CycLone
Old   October 24, 2008, 14:16
sandy
Thanks. I am new for Fluent, but I know CFX. For a rotor/stator case, in CFX I just make two meshes (rotor.gtm and stator.gtm), and then load them in CFX-pre and define the interface. Suppose I can export rotor.msh and stator.msh using CFX-mesh. How to do this in Fluent? It seems that you must combine them as one mesh file in Fluent. Thank you.
Old   October 24, 2008, 15:14
sandy
btw. I could save the cmbd file. But I could not find anywhere in the Tools menu I could export a .msh file.
Thanks.
Old   October 24, 2008, 17:00
CycLone
It should be under the tools menu in the Meshing tab (not CFX-Mesh). Are you using version 11?
-CycLone
Old   October 26, 2008, 02:27
andy
send me your email address. I will send you the complete settings(I have created my own tutorial for this procedure). regards Andy
Old   October 26, 2008, 02:34
andy
btw you must combine them in Gambit. Regards
Old   October 27, 2008, 06:54
sandy
yes. I am using version 11.0. Still could not find it. Thank you.
Old   October 27, 2008, 06:55
sandy
Thank you. I sent it to you. Really appreciate it.
Old   October 27, 2008, 08:20
  #11
CycLone
Hi Sandy,
Under the meshing tab, the first item under the Tools menu is "Write FLUENT Input File...". The option may be grayed out if you don't have the mesh object selected (it is context sensitive). If you still don't see it, you are either not using version 11 or you don't have the meshing tab selected.
Once you have exported your meshes, you can merge them within FLUENT (without going to Gambit) under the Grid menu by choosing "Merge...". However, you cannot replicate the meshes within FLUENT as you can in CFX.
-CycLone
Old   October 27, 2008, 09:21
  #12
sandy
Yes, I saw the "Write FLUENT Input File...", but it is grayed out. Could you please tell me how to have the mesh object selected (it is context sensitive)? Thank you very much.
Old   October 27, 2008, 10:16
  #13
CycLone
Click on it with your mouse.
Old   October 27, 2008, 10:26
  #14
sandy
Tried many times, but could not make it work. In the Meshing Tab, I tried to click on the Project, model under Project, also mesh under the Model, basically everything. I also clicked on my object in the window, but only one surface is turned to green. The "write fluent input file" keeps grey all the time. Do I need a particular license for that?
Old   October 27, 2008, 10:51
  #15
CycLone
Click on the object called "mesh". If you have it selected, the mesh should also be displayed in the viewer.
If the mesh is not displayed and you have "mesh" selected, you may have set your CFX-Mesh options not to write the mesh to the CMDB file. If that is the case, go to Tools>Options and under the CFX-Mesh options, opt to write the mesh to the CMDB file or both the CMDB file and a GTM file.
-CycLone
Old   October 27, 2008, 12:52
  #16
sandy
Hello CycLone,
Thank you very much. I finally got the mesh. But the .msh file is about 4 times as big as the .gtm file. For my case, the .gtm file is 10MB and the .msh is 40MB.
Old   October 27, 2008, 13:14
  #17
CycLone
Indeed. The GTM file is a very efficient format.
-CycLone
Fluent converting 'wall' to 'interior' BC for hybrid mesh DarrenC FLUENT 8 January 3, 2019 06:24
[ICEM] Using Surface Mesh from ANSA for Fluent Sim tommymoose ANSYS Meshing & Geometry 15 March 3, 2016 17:29
Can anybody tell me what does fluent do using MESH MOTION? enry FLUENT 0 October 6, 2010 12:54
Fluent: Mesh Adaption based on Gradient enigma FLUENT 4 July 15, 2010 17:36
