Velocity at each nodes::: how??
Old   October 24, 2008, 02:22
Default Velocity at each nodes::: how??
Nitin Dewangan
i always used to plot velocity vector, now i want to calculate velocity at each node. os there any options to get directly as it is available in fluent??
please reply.
thanks....
Old   October 24, 2008, 10:11
Default Re: Velocity at each nodes::: how??
CycLone
All the components of velocity are there. Look under the Variables tab in Post.
Velocity Velocity u Velocity v Velocity w
What are you trying to do?
-CycLone
Old   October 25, 2008, 16:16
nitin dewangan
hi cyclon.. i know, there is a option for velocity u, v and w i want to each velocity values at each node. i hope you understand the meaning of node: i.e. i made a meshing so value of each meshing corners. please try.. it is possible in fluent. i am looking it for ansys CFX.
please and thanks
Old   October 27, 2008, 09:13
CycLone
Hi Nitin,
Yes, I understand the meaning of node. CFX control volumes are centered about element vertices (i.e. nodes), so unlike FLUENT, there is no need to explicitly extrapolate values to nodes; they are already there.
I recommend you review the CFX theory documentation.
-CycLone
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 14:06
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 20:08
UDF velocity profile at nodes Emad FLUENT 2 January 29, 2009 07:35
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
