Mass Diffusion: Transient and Steady State BC |
November 12, 2008, 22:23 |
I am simulating mass diffusion through a porous media, so I created an additional variable (smoke) and used diffusive transport equation. I want to track smoke concentration (kg/m^3) at the outlet and plot it against time until the concentration reaches inlet concentration levels. After reading through CFX 11.0 Tutorial 4, I learned that I need to do a steady state simulations and use the results for initial condition in the transient simulation. However, I am a little confused about the boundary conditions in both steady state and transient simulations. Here's the BC I used Steady State Inlet Normal Speed = 0.05 [m s^-1] Additional Variable Value = 0 [kg m^-3] Outlet Relative Pressure = 0 [Pa] Additional Variable Value = 0 [kg m^-3] Transient Inlet Normal Speed = 0.05 [m s^-1] Additional Variable Value = 1 [kg m^-3] Outlet Relative Pressure = 0 [Pa] Additional Variable Value = 0 [kg m^-3] The result shows outlet concentration is very low in the order of 10^-5 kg/m^3. Am I making a mistake in assigning BCs? Can someone advice me on inlet and outlet BC ( speed and additional value) in both steady state and transient simulation. Sorry for such a long message. Please let me know if I can provide any other details. Thanks |
November 15, 2008, 15:16 |
Re: Mass Diffusion: Transient and Steady State BC
There is no problem with your results, the concentration in outlet is very low. Do you have an analitical solution for this problem? I have one and the concentration in the outlet is 1 and in outlet is 0. In the simulation and Peclet's number = 0,01, the concetration is 1 (inlet) and 1,53E-06 (outlet). So your results are not bad.
November 15, 2008, 15:18 |
There is no problem with your results, the concentration in outlet is very low. Do you have an analitical solution for this problem? I have one and the concentration in the inlet is 1 and in outlet is 0. In the simulation and Peclet's number = 0,01, the concetration is 1 (inlet) and 1,53E-06 (outlet). So your results are not bad. Sorry for my bad english.
November 19, 2008, 00:52 |
Thanks Joao.
Think I understand now. |
Steady State Vs Transient answers | Kushagra | CFX | 25 | July 23, 2017 03:20 |
Solver for transonic flow? | Martin Hegedus | OpenFOAM Running, Solving & CFD | 22 | December 16, 2015 04:59 |
Steady state vs. mean transient analysis of flow behind a circular cylinder | Heini | Main CFD Forum | 1 | June 9, 2011 06:47 |
time step and iterations in steady state problem using transient solver | jing113cn | FLUENT | 2 | January 15, 2010 03:18 |
Transient vs Steady State | Adam | CFX | 1 | April 12, 2007 11:34 |
