Idea Gas calculation vs Simlation not same !!!!!
Old   October 31, 2010, 09:49
Default Idea Gas calculation vs Simlation not same !!!!!
Thanathat
P9408 is on a distinguished road
My project I try to heat up the air to make a higher pressure in the reactor's cavity. After I do the simulation I found Pressure increased aound 0.001 ATM but from my calculation by P1/P2 = T1/T2 ( Constant Volume) I found the pressure will be 1.25 ATM ( It mean Pressure must increase 0.25 ATM), so It have any suggestion about the simulationin to compare between Idea Gas ( Constant Volume) vs Simulation result ANSYS or CFX ????
P9408 is offline   Reply With Quote
Old   October 31, 2010, 17:15
CFX is accurate in modelling ideal gases. There is a problem in your simulation. Can you describe your test model and boundary conditions?
Parallel User Defined Real Gas Model aeroman FLUENT 4 July 1, 2015 06:09
Calculation of burned gas inside tube Algimantas OpenFOAM 1 October 14, 2010 04:04
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
multicomponent gas calculation imbalance? Li Pengfei CFX 0 October 25, 2008 23:43
gas expansion in pipe crack propagation Marco Evangelos Biancolini Main CFD Forum 2 October 4, 2000 10:41
