-   -   ICEM periodic boundary (http://www.cfd-online.com/Forums/cfx/26698-icem-periodic-boundary.html)
CG CHEN November 20, 2008 08:30
Hi,all,
I would like to generate the tetrahedral grid by using ICEM. My problem is I have a pair of periodic boundaries and the grid generated on these two boundary surfaces should be same. But I couldn't not find such kind of functions in ICEM to satisfy my requirements. I'm a beginner in using ICEM. Thank you for your help in advance.
Ahmad Al-Zoubi November 20, 2008 09:29
Re: ICEM periodic boundary
Hallo CG CHEN,
Go to Mesh ==> Global Mesh Setup ==> Global Mesh Parameters ==> Setup Periodicity.
Good luck.
Ahmad
CG CHEN November 20, 2008 09:46
Thank you for your reply!
I found that function. But when I choose translational periodic, the only choice is "offset", I'm not sure if it is enough for set the periodic boundaries, for example, the computational domain is a cube and top and bottom surfaces are periodic.
sangrampp November 14, 2010 08:09
Originally Posted by CG CHEN
;90954
you should choose as offset whatever the dimension of the cube is.
s_azizmohammadi October 10, 2011 09:44
Hi guys,
I am new user in ICEM CFD meshing. I wanted to create a periodic triangular mesh in a 2D rectangle. I used "Mesh ==> Global Mesh Setup ==> Global Mesh Parameters ==> Setup Periodicity" and translational one and set the offset as size of rectangle.
Now I have to define opposite edges to specify which edges should have periodic condition. I don't know how can I do that. I tried to create block but I don't know the different options over there.
It would be appreciated if somebody could give me some hint to solve the problem or share a documents that could help me.
Regards,
Siroos
singer1812 October 10, 2011 14:21
Put this in the Meshing Forum?
Try putting the edges into parts. I think you can use those parts as the periodic choices. I dont work with 2D ICEM much, but works fine for 3D.
s_azizmohammadi October 11, 2011 02:56
Ok. Thanks, I will do that.
