-   -   icem script (http://www.cfd-online.com/Forums/cfx/26723-icem-script.html)
prad November 26, 2008 04:52
icem script
Hello! I'd posted this some time ago. I've got 3 icem .rpl scripts to run my simple geometry creation, meshing and conversion to .cfx5 format. All 3 scripts run individually at the DOS prompt as well as in icem replay mode. If I load the commands into a .bat file only the first command is run. The window then closes. Has anyone encountered this before? Suggestions are requested and are welcome. Prad The commands are: echo ICEM Tetin "C:\Prog...........icemcfd\win\bin\icemcfd.bat " -batch -script icemcfd_tin.rpl echo ICEM Mesh "C:\Prog..........icemcfd\win\bin\icemcfd.bat" -batch -script icemcfd_hex.rpl echo ICEM cfx5convertion "C:\Prog...........icemcfd\win\bin\icemcfd.bat " -batch -script icemcfd_con.rpl
Rogerio Fernandes Brito November 26, 2008 06:36
Re: icem script
Can u show us an example of this icem script?
Make the upload in http://rapidshare.de/
Thanks!
prad November 26, 2008 08:19
Re: icem script
There's really nothing more to it: the tin is a 2d square. The 2d planar blocking, edge definition and meshing is defined in the icemcfd_hex.rpl Conversion to .cfx5 format is in the last .rpl. Put all three in a test.bat and double click, only one line runs.
Rogerio Fernandes Brito November 26, 2008 08:55
Re: icem script
Is this the code?
JS December 16, 2008 15:32
Re: icem script
I'm not sure the connection between the scripts. Each script includes an 'exit' command at the end of line?
Saima July 23, 2010 16:30
Do u know wat is batch command for CFX.
my Mesh is in ICEM and every time it will be change , so i want to gice CFX commands starting with msh file. Do u know the way? If yes pls let me know.
Regards,
Originally Posted by prad
;91018
