December 9, 2008, 10:29 |
concentration of n2o
I need to examine the concentration of n2o in a room. The source of n2o is a person breathing with the mixture gas contains of n2o(40 ppm) and air. The airflow from the mouth is 7 l/min. I need to obtain results of n2o distribution in the room. I have a lot of problems with setting it up as well as preparing results in post, which I'd like it to be in ppm units. I will be gratefull for any advise.
December 9, 2008, 17:30 |
Re: concentration of n2o
hi,
This should be easily modelled with a passive scalar. In CFX-Post you should be able to convert from the solver units (probably kg of n2o per kg of air) to ppm for visualisation. Glenn Horrocks |
December 10, 2008, 06:31 |
The problem is that I've only managed to give quantity of N2O in [kg/s]- I've made it in CFX Pre.(I'm not sure if I set it up correctly ). More details, please - I'm not advanced user.
Display Modes | |
dpm concentration | HK | FLUENT | 0 | March 6, 2008 05:44 |
Concentration Scale Data Interpretation | usker | Siemens | 4 | October 23, 2007 20:30 |
negative species concentration again | Andrew Garrard | FLUENT | 0 | March 22, 2005 11:36 |
initial concentration in multicomponent mixtures | isidro | Siemens | 0 | April 26, 2004 07:40 |
mole concentration of species (kmole/m3) | neihad@hotmail.com | FLUENT | 5 | August 6, 2003 01:55 |
