December 11, 2008, 20:15 |
Wavemaking resistance of a submarine
I am a student trying to investigate the wave making resistance of a submarine traveling just below the surface using CFD. I am very new to CFD and would greatly appreciate any adivce at all on how to go about modeling the problem. Thankyou, Sam |
December 14, 2008, 15:59 |
Re: Wavemaking resistance of a submarine
Well... What can one say... I have successfully made this calculations for a surface hull. My learning period was about 4 months full time before I could successfully generate a solution, and I now use 20 CPU cores w 20GB RAM to run for about 100hrs to get one solution.
It is a difficult problem. So don't fool yourself into thinking you can do it in a week or two... The mesh is the key, as usual. Once you have a good mesh everything is easy. But you need about 10mm vertical resolution at the water surface, more than 5xhull size domain in all dimensions, and very good Y+ values around the hull. I don't think you can do it with unstructured tet's, either you get too little vertical resolution at the surface or your element count will blow through the celing. I use fully structured mesh with 6M elements, 10mm vertical res at surface up to 0.4 m res at domain boundary, Y+ = 20 around the hull, SST turbulence model. There is a very good section of how to set up the free surface model in the CFX manuals. |
December 14, 2008, 16:10 |
Thanks very much,
I appreciate the advice its good to get a starting point. Luckily I have all year to work on the project and a few decent clusters at my use. I have read in a few places that VOF modeling is the best way to tackle a free surface do you believe this would be applicable for my model? |
December 15, 2008, 15:49 |
Yes, certainly.
Ansys CFX-Solver Modeling Guide, pages 196-ff |
Inertial Resistance and Viscous Resistance Data | ravitejakatragadda | FLUENT | 5 | May 10, 2018 04:16 |
Ship Wave Making Resistance | Yasser | CFX | 8 | May 27, 2017 08:28 |
Ship resistance | tobino | FLUENT | 0 | June 27, 2011 20:31 |
adapt viscous resistance based on velocity / UDF | Häwimeddel | FLUENT | 2 | April 20, 2009 10:08 |
tube bank inertial resistance coefficients | Brian | FLUENT | 0 | September 8, 2004 09:04 |
