December 22, 2008, 12:15 |
CFX CPU-Fan not Converging
Hi I am currently working on a third year project to design an optimised CPU FAN. I currently trying to run CFD analysis (characteristic graphs)on an existing design. to do so i have created the blade geometry and have imported it into Tubogrid. the mesh was created and refined such that all mesh statistic errors are below 1%
I then used CFX-Pre, and using the "turbomachinery" mode i chose machine type to be "FAN" and this way i managed to define all boundary conditions. I have assumed a shroud tip clearance of 0.4mm and an inlet pressure of 101300 pa and an exit pressure of 101350pa. the residual target i have set is 10^-5 but however i try the solver will not converge?! i have tried also using the energy methods (total energy/ isothermal) but have not got anywhere. my major problem is even when i stop the solver after it srarts fluctuating at about 4 X 10^-4 the result file gives a blade loading graph that does not make sense(invalid). i have got print screens of the blade loading and also the convergance history and i can also email them if they can explain anything?! i would dearly appreciate help as i am pretty behind on my third year project. many thanks Danyal. |
December 22, 2008, 12:36 |
Re: CFX CPU-Fan not Converging
would you please send me your file? Please send me the out file together. wuzhiyongspecial@gmail.com
December 22, 2008, 16:17 |
December 24, 2008, 01:11 |
Hi
Try with inlet pressure boundary and outlet mass flowrate boundary. try with different mass flowrates. BOL |
Jet fan and Tunnel simulation | ahlo7 | CFX | 9 | November 13, 2019 04:54 |
Simulation of Axial Fan Flow using A Momentum Source Subdomain | Liam | CFX | 28 | July 16, 2013 08:24 |
[ICEM] Node Number vs. Node_ID & ICEM vs. CFX | Araz | ANSYS Meshing & Geometry | 1 | April 25, 2011 11:03 |
Propeller Fan Curve Simulation | Teng_YJ | FLUENT | 2 | February 16, 2009 19:37 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
