Fully Developed Flow at an Inlet
Old   January 12, 2009, 16:27
Default Fully Developed Flow at an Inlet
Ed Mueller
Hey all,
I am doing an analysis on cavitation in a pump in CFX. My inlet BC is a static pressure and my outlet BC is a mass flow rate. My question is: how can I get a fully developed flow at the inlet?
I know one way would be to extend the inlet pipe, but since my Re = 10^6, I would need to extend it to 44 times my diameter, which is not feasible. Any ideas on how I could specify a fully developed flow and static pressure for my inlet Boundary Condition?
Thanks,
Ed Mueller
Old   January 13, 2009, 06:31
Default Re: Fully Developed Flow at an Inlet
wan
1.normally for a flow in cavity, we use mass flow/velocity at inlet and static pressure at outlet. 2.If you are using water, you can refer to some paper that using analytical solution to know the developing region length, peak velocity and mean velocity.
Old   January 13, 2009, 08:46
LKF
If you were to set your outlet BC as static pressure, then you could use CEL to define a fully developed flow profile at the inlet.
Is there a particular reason why you want your mass flow defined as an outlet BC and your inlet BC as static pressure?
You could also study what the effect is of setting the Turbulence parameter for your inlet static pressure to Zero Gradient - this setting is recommended for fully developed turbulence conditions.
Old   January 13, 2009, 09:02
Ed Mueller
Because I am modeling the cavitation of the pump, static pressure at the inlet is very important. Is there anyway to keep the static pressure at the inlet as well as define the velocity profile?
Old   January 13, 2009, 11:18
LKF
Ed,
You can define a Total Pressure profile at your inlet using a velocity profile function to calculate the dynamic pressure - basically a dynamic pressure profile plus your desired inlet static pressure.
To ensure that your simulation runs with the right flow rate, you'll need to accurately define the outlet static pressure w.r.t. the desired inlet static pressure (i.e. the static pressure change between inlet and outlet). This value could be iterativley determined (or perhaps you already have it from previous runs. You could adjust the outlet static pressure on the fly with mass flow as a monitor point that you watch in the solver manager.
It is likely that other more experienced people will have simpler and perhaps more accurate means of accomplishing your goal, but this approach should work . . .
Old   January 13, 2009, 11:50
LKF
In hindsight, I believe my previous post is no different than defining an inlet velocity profile and an outlet static pressure. You would just iteratively adjust your outlet static pressure until the inlet static pressure meets your desired value.
Of course you are relying on the CFD model to accurately predict the static pressure change across the domain so it would be wise to validate the result in some manner.
Triangular mesh - fully developed flow between parallel plate Amir_Ghasemi Main CFD Forum 3 November 28, 2010 04:52
translational periodic BC vs Fully Developed Profile at Inlet Prakash.Paudel FLUENT 1 August 20, 2010 11:01
initial condition for fully developed flow kmgraju CFX 3 August 6, 2010 05:57
Fully developed flow ,CEL expression kmgraju CFX 0 August 6, 2010 04:15
BC for fully developed turbulent flow in a pipe mmd014 FLUENT 2 May 22, 2009 06:50
