Memory error
Old   December 31, 2008, 05:26
Default Memory error
VSB
Hi all,
This is the error I get
solver-pvm.exe - Application error
The instruction at "0x039a178f" referenced memory at "0x1af7ca38". The memory could not be "read"
Any suggestions?
Regards, VSB
Old   January 2, 2009, 04:43
Default Re: Memory error
whiz
I guess you made some mistakes on boundary conditions.
Old   January 5, 2009, 05:31
whiz is right - it probably means you are incorrectly calling a CEL expression or giving a incorrect CCL value. Have a close look at the CCL you have written. Check it by running it through CFX-Pre.
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 18:54
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
attach/detach (valve opening/closing) phsieh2005 OpenFOAM Running, Solving & CFD 2 March 21, 2009 05:18
user defined function cfduser CFX 0 April 29, 2006 10:58
