January 8, 2009, 14:16 |
invalid results in cfx
Hi, im currently modelling flow through a cpu fan and i have managed to make the model converege to a residual of 10^-5 The mesh was created in turbo grid with minimal errors and the boundary conditions were specified as an inlet of 101300pa and outlet of 101335pa a tip clearance of 4mm was aso specified... unfortunately the results i am getting seem to be very obscure: a total efficiency of over 100 % shows up in the report.. i can email you the html report file if this helps resolve the problem.
January 8, 2009, 16:15 |
Re: invalid results in cfx
Have you done all the normal checks? Check the sensitivity to convergence, time step size (if transient) and mesh size. Glenn Horrocks |
January 13, 2009, 07:53 |
tell me number of iterations.
how did you model the fan? |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
Pros and Cons for CFX, CFdesign, COMSOL | Val | Main CFD Forum | 3 | June 10, 2011 02:20 |
CFX vs. Fluent Results | n.sharifi | CFX | 8 | November 3, 2010 16:40 |
Centrifugal Fan Case Study Results Required using CFX | kambireddy | CFX | 0 | October 8, 2010 05:46 |
Import results to CFX post | MatjazR | CFX | 1 | October 17, 2005 09:07 |
