SCL_RESCH error
I got this error message:
"Error #004100025 has occured in subroutine SCL_RESCH. Message: A floating point overflow has occured. Check solver parameters, bcs and mesh quality. The calculation will now be terminated. Note: if this error occurs at the first iteration, that may be caused by the initial guess, eg- a zero initial velocity and zero dynamic viscosity." I have checked the mesh quality, bcs etc., everything is all right. Also, i get this error after about 25 iterations. Could it be because of computer running out of memory? Thanks in advance |
Re: SCL_RESCH error
No, the problem is something is diverging. Have a look to see what is diverging. Glenn Horrocks |
