Two differents BC in the same surface
Old   January 31, 2009, 12:12
Default Two differents BC in the same surface
Miguel Baritto
Hi all.
I'm simulating flow in a pipe with heat transfer. At the pipe wall I need to specified heat flux just for first quater of total lenght and wall temperature for the rest. My problem is that I can't set two different kinds of BC at the same surface. Can I do something to do that in CFX-Pre? or Do I have to compose the wall for two different surface and then meshing?
Thanks
Miguel
Old   February 1, 2009, 05:41
Default Re: Two differents BC in the same surface
johnny
You should create two separate 2D regions for the wall in CAD before meshing.
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
