Solver crashes (PVM parallel)
Old   January 30, 2009, 02:51
Default Solver crashes (PVM parallel)
Marco Müller
Hi all,
when setting up an CFX 11 run in parallel (PVM local) on my Dual Core (Intel Xeon) PC, the solver crashes after sucessfully patitioning and writes only the following:
"An error has occurred in cfx5solve: The ANSYS CFX solver has terminated without writing a results file. Command on host ansysxeonserv (ANSYS_XEON_SERV) exited with return code 0.
End of solution stage.
The following user files have been saved in the directory E:\fe-calc\g06\g06_020: fort.99"
I've searched a lot and phoned with the hotline, but hadn't any success. Licence should be no problem. I also tryed different def-Files. I put you some file entries which might be interesting for the problem:
*** case\fort.99: ***
Error (at msgget.F): Cannot find message file, english_msg.txt. Please make sure that the environment variable CFX_DATA_DIR is set to the right directory. The run will STOP.
*** hosts.ccl: ***
PARALLEL HOST LIBRARY:
HOST DEFINITION: ansysxeonserv
Remote Host Name = ANSYS_XEON_SERV
Installation Root = C:\Progra~1\AnsysI~1\v%v\CFX
Host Architecture String = winnt-amd64
END # HOST DEFINITION ansysxeonserv
END # PARALLEL HOST LIBRARY
*** Out-file: ***
Installation Root = C:\Program Files\Ansys Inc\v%v\CFX
END
*** case\PVMhosts: (backed up before crashing) ***
# PVM hosts file automatically generated from CFX-5 host database &ANSYS_XEON_SERV dx=C:\Program Files\Ansys Inc\v110\CFX\tools\pvm3.4.4_11-2\lib\WINX64\pvmd3.exe
*** ...user\temp\pvml.-1.ANSYS_XEON_SERVER ***
[pvmd pid2872] parsehost(): unknown option "Inc\v110\CFX\tools\pvm3.4.4_11-2\lib\WINX64\pvmd3.exe"
[pvmd pid2872] parsehost(): unknown option "Files\Ansys" [pvmd pid2872] readhostfile() E:\fe-calc\g06\g06_020.dir\PVMhosts 2: errors
[pvmd pid2872] readhostfile() E:\fe-calc\g06\g06_020.dir\PVMhosts: 1 errors in hostfile
[t80040000] ANSYS_XEON_SERVER (192.168.1.55:2706) WINX64 3.4.4
[t80040000] ready loclinput() read: 10054
[t80040000] loclinput() marking t40003 dead
[t80040000] dm_halt() from (ANSYS_XEON_SERVER), halting...
[t80040000] work() pvmd halting
[t80040000] pvmbailout(0)
As you can see, I removed the spaces in the file path in hosts.cll file with no succeed. Furthermore I set up the environment variable CFX_DATA_DIR! CFX keeps on messaging the same nonsens. (BTW: MPICH doesn't work, too, but I didn't investigate that topic)
Thanks a lot for reading that much and for possible help!
Marco
Old   February 2, 2009, 01:46
Default Re: Solver crashes (PVM parallel)
Marco Müller
some experts with ideas? Thank you!
Marco
Old   February 4, 2009, 02:51
Marco Müller
hope dies last...
2D pseudo-spectral (Chebyshev) parallel Helmholtz solver package magicsquirrel Main CFD Forum 0 July 13, 2011 10:45
Problem with PVM Distributed Parallel nolebb CFX 2 April 19, 2009 19:25
PROBLEM IN SOLVER RUNNING PARALLEL Íñigo CFX 3 February 4, 2007 05:08
Which parallel solver is most suitable for my app? zonexo Main CFD Forum 1 November 17, 2006 09:46
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
