Turbulence
Im doing a FSI simulation and all equations converge except for the turbulence equation. With k-eps, I get a FINMES error. With SST, O-TurbFreq shows following lines at timestep 57 and 58:
57: | O-TurbFreq | 0.96 | 3.9E-03 | 1.4E-02 | 44.3 2.0E-06 OK| 58: | O-TurbFreq | NaN | NaN | 2.3E+00 | 11.8 0.0E+00 OK | The other equations converge and the run ends normally. How come one of the turbulence won't converge? These are my mesh values: Minimum Orthogonality Angle [degrees] = 63.5 OK Maximum Aspect Ratio = 82.0 OK Maximum Mesh Expansion Factor = 3.6 OK Cheers |
Re: Turbulence
Does this error occur in the 1st iteration? If yes, you need to change the initial conditions. If not, try to change the mesh size.
Re: Turbulence
Abduri,
Have you read the documentation on "obtaining convergence"? Also some more tips are here: http://www.cfd-online.com/Wiki/Ansys...gence_criteria Glenn Horrocks |
