Create a surface inside a volume
Hi all
I am trying to make some simplifacatiions on modelling many persons inside a room and would therefore like to model all persons as a surface without any thickness inside a solid enclosure. Is this possible and how to do it? Kind regards MAT |
Re: Create a surface inside a volume
You can either specify a heat flux on an external surface or you can specify a thin surface inside the domain and specify a heat flux on that. Glenn Horrocks |
