Leakage through a small clearance crack.
Old   February 4, 2009, 12:00
Default Leakage through a small clearance crack.
Mike Jenkins
Does anyone have any experience setting up this type of problem? I am trying to determine the leakage rate through a clearance type diameter fit of two parts.
I am setting up the problem in this manner:
Part is assembled into the tube. Negative of the part and tube is made within ProE. Step file of the negative is exported. I can clearly see the connected crack between the two volumes. The crack has very tiny mesh compared to the connected volumes. Pressure pulse of 50 psi is applied to the "inlet". Vacuum pressure of 1 psi is applied to the "outlet".
When veiwing the results, I can see the pressure differential form around the "crack" but there is no velocity streamlines forming through it. I have even tried using up to 10,000 seed points thinking maybe it was not high enough but to no avail!
Does this just mean that there will be no leakage or have I set up the problem incorrectly?
Old   February 4, 2009, 13:44
Default Re: Leakage through a small clearance crack.
Rajee Assudani
It depends on the size of the clearance. How small is the clearance? Also, if the streamlines are visible on both sides of the crack, but not in the crack, then it's a visual artifact. Does the leakage flow rate seem reasonable? Is the solution converged?
Old   February 4, 2009, 14:09
Mike Jenkins
Bore fit clearance is about .60/.37 so the crack is about .37/2 mm thick (.185 mm). The fluid is air and the mesh size is about .01 min so I think it is okay.
If you are able to see the results does this not mean that the solution has converged? If not, how do you check?
Old   February 4, 2009, 16:21
CycLone
Where are you seeding the streamlines? If the crack is very small, then it will be very hard to find a streamline that goes through. Try seeding the streamline from within the crack by seeding them from a slice plane that cuts through them, for instance. Calculate the streamline forward and backward to see where they come from and where they are going.
By the way, if the crack is very small relative to the domain, you should probably run the solver in double precision.
-CycLone
Old   February 5, 2009, 08:16
Rajee Assudani
Yes, the dimensions and the relative mesh size sounds alright. If you are able to see the results, that does not mean that the solution has converged. You can see the results for a non-converged solution also if the solver finishes the number of iterations specified. If the error residuals reach the minimum specified target, then the solutions is considered to be converged.
Old   February 5, 2009, 09:38
Mike Jenkins
That worked! I used double precision in the solver and created a plane through the crack. Then by making a plane in the middle of the crack and seeding from the crack in both directions the leak was revealed!
why did Time step is too small in stiffbs? satum FLUENT 1 December 10, 2012 09:15
Small influence of convection in PISO if Courant number is small sebi OpenFOAM 0 February 22, 2011 14:55
what happens if y+ is too large or too small Bo Jensen Siemens 12 February 19, 2003 23:31
Tip Clearance Drona CFX 0 October 17, 2002 05:25
small size holes simulation brian ko Phoenics 5 October 22, 2001 12:53
