drag coefficient
Old   February 25, 2009, 01:47
Default drag coefficient
Chetan
Plese suggest me how to calculate drag coefficient of bluff body.
Old   February 26, 2009, 16:45
Default Re: drag coefficient
  1. <LI>Do accurate simulation.</LI> <LI>Use CFX-Post to get drag force on the body.</LI> <LI>Calculate drag coefficient using standard drag coefficient formula.</LI>
Old   March 2, 2009, 22:56
Chetan
for calculation i need pressure at points... how to draw polyline on body and CEL for a problem kindly give me proper guidence as i am new to this topic.
Old   March 3, 2009, 16:54
You can either set up monitor points which allow you to track the pressure as the simulation progresses or you can extract the pressures as post-processing in CFX-Post.
Drag Coefficient Convergence Problem John FLUENT 18 June 24, 2023 09:22
drag coefficient in ansys fluent 12.0 krishna FLUENT 19 April 12, 2018 00:49
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 06:24
Drag coefficient for parcels in dieselFoam sebastian_vogl OpenFOAM Running, Solving & CFD 5 December 31, 2008 12:19
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 08:43
