February 9, 2009, 13:25 |
Inlet boundary conditions
Dear all,
good evening. My name is Mattia and I am a PhD student at the Delft University of Technology (The Netherlands). I am currently working in the turbomachinery field and I am focused on the analysis of a centrifugal compressor used in a micro gas turbine. The actual configuration has a vaneless diffuser and my idea is to enhance its performance by designing a vaned diffuser. Anyway, let's talk about CFD. I want to make a "rough estimate" of the flow field inside the vaneless diffuser and I am using CFX as CFD software. I am simulating only one portion of the diffuser and only the diffuser itself. I have a 3D mesh. Based on same papers I read, the best boundary conditions to use are pressure and temperature at the inlet (plus flow direction) and mass flow outlet. Thus, this is what I am trying to do and here the problems come out. Of course I know the mass flow and I calculated the inlet conditions at the diffuser inlet (=impeller outlet) by means of velocity triangles (no experimental data available): it means I know the total pressure and temperature, plus absolute velocity (and its components) and the flow angles. The biggest problem I have concerns the flow direction: how can I set it properly? Since I know the angles from the velocity triangles, I shouldn't have any trouble, but on the contrary I do have problems. Can you please help me with that? Moreover, I read in the "help manual" that the total pressure to set as inlet b.c. is the RELATIVE TOTAL PRESSURE: does this mean that I have to subtract, from the calculated value, the reference pressure (=1 atm)? I can provide you more details if needed. Thank you very much! Kind regards, Mattia. |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
inlet boundary conditions | mattia | Main CFD Forum | 0 | February 11, 2009 06:06 |
Boundary conditions at Inlet for k and epsilon | Tanmay | FLUENT | 1 | January 26, 2009 10:42 |
periodic boundary conditions at the inlet | Nacho Tauste | FLUENT | 0 | January 14, 2009 12:34 |
how to set supersonic inlet boundary conditions | xqy | Phoenics | 2 | August 31, 2002 06:06 |
