No results for solid domain
Old   March 10, 2009, 11:23
Default No results for solid domain
Gary Holland
Hello users,
I'm new to cfx and am running a fairly simple model (a solid cylinder with a fluid region inside of it). The model converges with no problems however when i come to post-process the results i have no results for the solid tube, only for the fluid region. The solid tube section does have a film externally however i don't think this is causing the problem.
Thanks for any advice.
Old   March 10, 2009, 16:12
Default Re: No results for solid domain
andy2o
Please post the CCL for your case to allow us to help. This is the text output you see at the top of the text window in CFX solver manager. We just need to see the bit near the top which describes the model setup - not all the residual values which get printed later.
Regards, andy
Old   March 11, 2009, 08:05
Gary Holland
Hi Andy,
Thanks for your reply. Please see below the CCL as requested. As the model convergres without any obvious problems, I'm hoping that this may just be something simple. I've used the 'Air at 25 degrees' option for the fluid as I 'presume' that Air Ideal Gas is more for compressible flow scenarios.. Also, I noticed that my CCl doesn't contain geometry info - so I hope that I have given you the information which you referred to.
Thanks again, Gary.
LIBRARY:
MATERIAL: Air at 25 C
Material Description = Air at 25 C and 1 atm (dry)
Material Group = Air Data, Constant Property Gases
Option = Pure Substance
Thermodynamic State = Gas
PROPERTIES:
Option = General Material
Thermal Expansivity = 0.003356 [K^-1]
ABSORPTION COEFFICIENT:
Absorption Coefficient = 0.01 [m^-1]
Option = Value
END
DYNAMIC VISCOSITY:
Dynamic Viscosity = 1.831E-05 [kg m^-1 s^-1]
Option = Value
END
EQUATION OF STATE:
Density = 1.185 [kg m^-3]
Molar Mass = 28.96 [kg kmol^-1]
Option = Value
END
REFERENCE STATE:
Option = Specified Point
Reference Pressure = 1 [atm]
Reference Specific Enthalpy = 0. [J/kg]
Reference Specific Entropy = 0. [J/kg/K]
Reference Temperature = 25 [C]
END
REFRACTIVE INDEX:
Option = Value
Refractive Index = 1.0 [m m^-1]
END
SCATTERING COEFFICIENT:
Option = Value
Scattering Coefficient = 0.0 [m^-1]
END
SPECIFIC HEAT CAPACITY:
Option = Value
Specific Heat Capacity = 1.0044E+03 [J kg^-1 K^-1]
Specific Heat Type = Constant Pressure
END
THERMAL CONDUCTIVITY:
Option = Value
Thermal Conductivity = 2.61E-02 [W m^-1 K^-1]
END
END
END
MATERIAL: Steel
Material Group = CHT Solids, Particle Solids
Thermodynamic State = Solid
PROPERTIES:
EQUATION OF STATE:
Density = 7854 [kg m^-3]
Molar Mass = 55.85 [kg kmol^-1]
Option = Value
END
REFERENCE STATE:
Reference Specific Enthalpy = 0 [J/kg]
Reference Specific Entropy = 0 [J/kg/K]
END
Option = Value
Specific Heat Capacity = 4.34E+02 [J kg^-1 K^-1]
END
Option = Value
Thermal Conductivity = 60.5 [W m^-1 K^-1]
END
END
END END FLOW:
SOLUTION UNITS:
Angle Units = [rad]
Length Units = [m]
Mass Units = [kg]
Solid Angle Units = [sr]
Temperature Units = [K]
Time Units = [s]
END
SIMULATION TYPE:
Option = Steady State
EXTERNAL SOLVER COUPLING:
Option = None
END
END
DOMAIN: ITube
Domain Type = Solid
Location = B10
Solids List = Steel
BOUNDARY: Default Fluid Solid Interface Side 1 1
Boundary Type = INTERFACE
Location = F15.10
BOUNDARY CONDITIONS:
HEAT TRANSFER:
Option = Conservative Interface Flux
END
END
END
BOUNDARY: Film
Boundary Type = WALL
Location = F11.10,F12.10,F13.10
HEAT TRANSFER:
Heat Transfer Coefficient = 10 [W m^-2 K^-1]
Option = Heat Transfer Coefficient
Outside Temperature = 19.6 [C]
END
END
END
DOMAIN MODELS:
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Option = None
END
END
INITIALISATION:
Option = Automatic
INITIAL CONDITIONS:
TEMPERATURE:
Option = Automatic with Value
END
END
END
SOLID MODELS:
HEAT TRANSFER MODEL:
Option = Thermal Energy
END
THERMAL RADIATION MODEL:
Option = None
END
END
END
DOMAIN: ITube_Air
Coord Frame = Coord 0
Domain Type = Fluid
Fluids List = Air at 25 C
Location = B14
Location = F15.14
HEAT TRANSFER:
END
WALL INFLUENCE ON FLOW:
Option = No Slip
END
WALL ROUGHNESS:
Option = Smooth Wall
END
END
END
BOUNDARY: Fluid_Film_Bottom
Location = F16.14
HEAT TRANSFER:
END
Option = No Slip
END
WALL ROUGHNESS:
END
END
END
BOUNDARY: Fluid_Film_Top
Location = F17.14
HEAT TRANSFER:
Heat Transfer Coefficient = 20 [W m^-2 K^-1]
END
Option = No Slip
END
WALL ROUGHNESS:
END
END
END
BOUNDARY: Flux
Location = F18.14
HEAT TRANSFER:
Option = Adiabatic
END
Option = No Slip
END
WALL ROUGHNESS:
END
END
BOUNDARY SOURCE:
SOURCES:
EQUATION SOURCE: energy
Flux = 46.358 [W m^-2]
Option = Flux
END
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
Buoyancy Reference Temperature = 19.6 [C]
Gravity X Component = 0 [m s^-2]
Gravity Y Component = 0 [m s^-2]
Gravity Z Component = -9.81 [m s^-2]
Option = Buoyant
BUOYANCY REFERENCE LOCATION:
Option = Automatic
END
END
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
END
Option = None
END
TURBULENCE MODEL:
Option = k epsilon
BUOYANCY TURBULENCE:
Option = None
END
END
TURBULENT WALL FUNCTIONS:
Option = Scalable
END
END
INITIALISATION:
Option = Automatic
INITIAL CONDITIONS:
Velocity Type = Cartesian
CARTESIAN VELOCITY COMPONENTS:
U = 0 [m s^-1]
V = 0 [m s^-1]
W = 0 [m s^-1]
END
K:
Option = Automatic
END
STATIC PRESSURE:
Relative Pressure = 1 [atm]
END
TEMPERATURE:
Temperature = 292.6 [K]
END
END
END
END
DOMAIN INTERFACE: Default Fluid Solid Interface
Boundary List1 = Default Fluid Solid Interface Side 1 1
Boundary List2 = Default Fluid Solid Interface Side 1
Interface Type = Fluid Solid
INTERFACE MODELS:
Option = General Connection
FRAME CHANGE:
Option = None
END
PITCH CHANGE:
Option = None
END
END
MESH CONNECTION:
Option = Automatic
END
END
INITIALISATION:
Option = Automatic
INITIAL CONDITIONS:
U = 0 [m s^-1]
V = 0 [m s^-1]
W = 0 [m s^-1]
END
EPSILON:
Option = Automatic
END
K:
Option = Automatic
END
STATIC PRESSURE:
END
TEMPERATURE:
END
END
END
OUTPUT CONTROL:
RESULTS:
File Compression Level = Default
Option = Standard
END
END
SOLVER CONTROL:
ADVECTION SCHEME:
Option = High Resolution
END
CONVERGENCE CONTROL:
Length Scale Option = Conservative
Maximum Number of Iterations = 150
Solid Timescale Control = Auto Timescale
Timescale Factor = 1.0
END
CONVERGENCE CRITERIA:
Residual Target = 1.E-4
Residual Type = RMS
END
DYNAMIC MODEL CONTROL:
Global Dynamic Model Control = On
END
END END COMMAND FILE:
Version = 11.0
Results Version = 11.0 END EXECUTION CONTROL:
INTERPOLATOR STEP CONTROL:
Runtime Priority = Standard
EXECUTABLE SELECTION:
Double Precision = Off
END
MEMORY CONTROL:
Memory Allocation Factor = 1.0
END
END
PARALLEL HOST LIBRARY:
HOST DEFINITION: gb002ws0295
Host Architecture String = winnt
Installation Root = C:\Program Files\ANSYS Inc\v%v\CFX
END
END
PARTITIONER STEP CONTROL:
Multidomain Option = Independent Partitioning
Use Large Problem Partitioner = Off
END
MEMORY CONTROL:
END
PARTITIONING TYPE:
MeTiS Type = k-way
Option = MeTiS
Partition Size Rule = Automatic
END
END
RUN DEFINITION:
Definition File = T:/Development/1. R&D Projects/DU004594 - analysis \
development/005 Engineering/3D Thermal Analysis/Analysis \
Files/Convection/Perdido I-Tube/WoS.def
Interpolate Initial Values = Off
Run Mode = Full
END
SOLVER STEP CONTROL:
END
LICENSE CONTROL:
Preferred License = 35
Shared License Port = 1601
END
MEMORY CONTROL:
END
PARALLEL ENVIRONMENT:
Number of Processes = 1
Start Method = Serial
END
END END
Old   March 11, 2009, 16:52
Craig Hildreth
Just an aside, your convergence criteria is not very strict. Be careful with these results.
Old   March 11, 2009, 21:11
Rikio
Gary,
I did not find inlet & outlet for the fluid domain, all the boundaries of domain, ITube_Air, are walls. What is your analysis target? Just to get the temp. distribution on the walls?
Rikio
Old   March 12, 2009, 03:23
andy2o
Gary,
I cannot see any particlar problems here.
1) When you run the problem, do you see a tab on the Solver Manager for the energy equation? Do you see residuals for the enthalpy (H) and temperature (T) in the solver output?
2) How are you post-processing it? What happens if you put a plane through the tube, passing through both the solid and the air domains; then define a contour on this plane (being careful to select either 'All Domains' or both the solid and air domains are selected in the definition of the contour, and select Temperature for the variable? (Sorry if this is too obvious - but you did say you're new to CFX...)
3) In multi-domain problems, I think CFXPost asks if it should load results from all domains (or just some of them) when you load the results file. This is useful for large models - but in your case make sure you load them all here! (You can tell it not to ask again about this in the future - so don't worry if you do not see this message)
Regards, andy2o
Old   March 12, 2009, 04:14
Gary Holland
Hello Craig, Rikio and Andy2o. Thank you for your posts.
Craig, with regards to the convergence criteria, if I remember correctly I used the default settings with residual target set at 1E-04; perhaps this could be reduced, unless it was other parameters which you were referring to?
Rikio, my intention is to model an enclosed volume using the buoyancy option to model the temperature distribution within the volume. As far as I am aware, I don't need to specify an inlet and outlet?? If you think my method for achieving this is incorrect, then please feel free to comment or suggest otherwise.
Andy, no those instrustions aren't too basic as this is the first simulation I've run with CFX. Actually I had already tried what you have suggested (creating a plane through both the solid and fluid domains) although this still doesn't seem to give me results for the solid tube section. I have also made sure that the two domains are selected for post processing when prompted. When solving, the residuals for enthalpy and temperature appear to be reducing without 'problems'.I'm beginning to think that maybe its a default setting somewhere that I may have adjusted, I may try recreating the simulation and trying again... While talking about post processing, is there a preferred package that CFX users use, or do most generally use CFX-post itself?
Thanks again, gary.
Old   March 12, 2009, 08:06
andy2o
You're correct - the RMS residual < 10e-4 is the default, but if you read the documentation you'll find they suggest you should have MAX residaul < 10e-4 (or less, 5e-5 for example) for accurate results. That isn't the cause of your current problem though, as CFX Post should display your results (accurate or not), but it is worth knowing.
What about the fluid results? Do they look sensible? Sensible temperatures (you're not getting millions of degrees C?!)? If so, it sounds like CFX is solving OK. So, it sounds like you must be having problems with CFX Post. I suggest you start from scratch in CFX POST (close it down, restart it and don't use any saved state files you've made). Perhaps look at the tutorials - there's one with a heater coil which includes solid materials - why not do that tutorial for guidance?
Obviously some variables, such as velocity, are not output for the solid region - so make sure you use variables that are defined in the solid region to create your plots.
Good luck. Do you have a CFX support contract? Why not give them a call? Otherwise perhaps someone else will pipe up with an answer, because I've never hit a problem like this before myself.
Andy
Old   March 12, 2009, 10:51
Gary Holland
Success! I decided to stick with my idea that the problem must be something simple as everything else seemed correct and there were no convergence problems. My post-processing choice was the value of 'total temperature' and for some reason this doesn't give any results for the solid region. If i change this to simply 'temperature', the results are there...! If you can explain what the difference is then that would be great as I can't find it in the manual...
Further to your question, yes I do have a CFX/workbench contact (was helpful with a couple of design modeller problems)
Thanks, gary.
Old   March 12, 2009, 20:20
Rikio
Gary,
There is no "Total Temperature" in a solid. It just exists in fluid domain, because it should be calculated based on static temperature and velocity. Obviously, no velocity in solid domain.
Rikio
Old   March 13, 2009, 03:30
  #11
Gary Holland
Hi Rikio,
That makes sense, thanks for your reply and help with this problem.
Gary.
Generate a CFD domain from FEA results Dave442 Main CFD Forum 0 August 3, 2011 12:42
initialize 3D domain with 2D results ivanbuz FLUENT 6 September 3, 2009 18:19
CFX Solver Memory Error mike CFX 1 March 19, 2008 07:22
rotating domain in rotating domain, different axis Robert Stringer CFX 3 December 4, 2006 07:04
Solver error message!!! IoSa CFX 1 September 14, 2006 04:48
