Different results starting the same def-file
Old   March 9, 2009, 08:04
Default Different results starting the same def-file
Adam Stuchlik
hi guys, Iīm investigating radial fans and have problems matching my experimental data. One problem is that when I start the same def-file with different (interpolation) res-files, e.g. pressure rise is totally different calculated. How can this be??
I have ICEM-hexa grids and use SST, steady, isothermal. Timescales, boundarys and so on are identical.
best wishes adam
Old   March 9, 2009, 08:26
Default Re: Different results starting the same def-file
CycLone
This simply means that you have multiple possible stable solutions. Which one you end up at depends upon the initial conditions. Basically it is hysteresis in your model. Look at how the two solutions differ. There is probably a separation zone in one which is not induced in the other.
-CycLone
Old   March 9, 2009, 09:01
Adam Stuchlik
Thanks, but this canīt be. I can reproduce my experimentally data (pressure rise) in one (or more) operating points (OP), whether Iīm coming from a higer or lower level one the pressure curve. So CFX canīt calculate different results (25% pressure difference) for one OP depending on the initial OP, right?! So are there other possibilities?
best wishes adam
Old   March 9, 2009, 10:57
Rajee Assudani
Is your solution converged? If it is not, then the solution (in this case - pressure) may show fluctuation between two result files.
Old   March 10, 2009, 05:23
Adam Stuchlik
both cases reach the same level of convergence. and the other monitorpoints (torque, force, density,...) differ only sparsely.
Old   March 10, 2009, 08:17
CycLone
It is still hysteris; perhaps more numerical, not physical. Your modeling assumptions (periodic symmetry for instance), mesh (is it fine enough?) and convergence level can all contribute.
Note that physically you can see similar behavior, where the performance will depend on whether you sped up or slowed down the system.
-CycLone
Old   March 10, 2009, 09:00
Adam Stuchlik
I donīt have symmetries, but massflow-inlet, static pressure opening (entrain) and frozen-rotor-interfaces between the stationary and rotating domains. What is fine enough? Grid has ~2.6 million nodes in the rotating and ~1.4 million in the stationary domain. y+ range is 1 to 40. convergence level is the same.
Old   March 10, 2009, 16:09
CycLone
Try clocking your interface (there is a clocking angle setting on the interface). You should do this when running Frozen Rotor anyhow. Alternatively you could run transient rotor stator and store the time average velocity field.
-CycLone
Old   March 11, 2009, 04:38
Adam Stuchlik
clocking interface? you mean rotational offset? anybody else an idea??
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 04:43
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 04:26
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
gcc and executable file from Mac to Linux simone Marras Main CFD Forum 0 April 8, 2007 15:49
