October 6, 2006, 00:50 |
axes
Hi All,
I know this maybe a no-brainer, but I'm Ansys cfx dummy. I was wondering how do I change the axes in which my geometry is already defined as. As in I what the y-axis to represent a different direction of my geometry. (I am NOT referring in how to actually change the view). Cheers |
March 18, 2009, 23:24 |
how to change axis
Go to CFX PRE:in that domain enter some options will show cordinates in that will change x or y or z |
March 19, 2009, 06:27 |
Rep Power: 17 |
Two ways come to mind in CFX-Pre.
1. Right click on your mesh file in the tree and select 'Transform Mesh'. This will allow you translate, rotate, reflect, or scale the mesh. You can either copy the original or delete the original. I suspect in your case you will delete the original. 2. You can add multiple coordinate systems in Pre, which you can use as reference coordinate systems for BC's. |
Multi rotating axes in OpenFOAM | waku2005 | OpenFOAM | 13 | August 30, 2012 08:23 |
How can I make the axes in a contour plot in tecplot as log scale | seminole | Tecplot | 0 | July 6, 2011 00:20 |
mixerGGI (OF15-dev): Rotation around two axes | fusij | OpenFOAM | 0 | February 13, 2011 20:57 |
restricting path-line xy-plots to specific axes ranges | j0nnymad | FLUENT | 0 | December 16, 2009 19:58 |
[OpenFOAM] About the cube axes in Paraview | rama | ParaView | 2 | April 23, 2007 16:16 |
