March 13, 2009, 23:36 |
Temperature gradient
Hi, I would like to get some help regarding temperature graident.
What I did is First, I defined two types of temperature gradient in CEL expression. e.g., TempGradS: Temperature.Gradient TempGradt: Temperature.Time derivative Next, I inserted additional variables for these two. In basic settings, variable type is unspecifed and tensor type is scalar. My questions are 1) This procedure is correct? 2) Does TempGrads (by the above definition and scalar setting in addtional variables) mean a root of (dT/dx)^2+(dT/dy)^2+(dT/dz)^2 ? 3) How to get these two gradients in CSV file format? Thank you so much and have a great day~! Jaho |
March 16, 2009, 06:32 |
Procedure is incorrect, i think. As far as i know, Temperature.Gradient is CFX-Post variable and it is VECTOR variable. To obtain gradient you want simply define CEL expression sqrt(T.Gradient X^2+T.Gradient Y^2+T.Gradient Z^2). It should work.
Zef |
Temperature gradient in CFX | Chander | CFX | 5 | January 7, 2015 03:00 |
specified shear at wall - temperature gradient - UDF - access violation error | senD | Fluent UDF and Scheme Programming | 9 | September 18, 2014 07:29 |
Wall correction for the temperature gradient | Hagen | OpenFOAM | 0 | March 7, 2011 20:04 |
Temperature Gradient at Wall | sven | OpenFOAM | 7 | November 1, 2010 17:25 |
temperature normal gradient on a boundary | Sandrine | Main CFD Forum | 2 | June 10, 2009 16:34 |
