March 17, 2009, 15:11 |
Meshing of circular pipe in CFX-mesh
Hi.
I'm new to CFX and need some help with my meshing. My geometry is a horizontal pipe (d=45mm, L=400mm) with a 90 degree bend. I want to simulate particle sedimentation in the bend. How should i mesh my geometry? Doe's anyone have suggestions to best mesh a circular pipe with finer mesh in the bend section? |
March 18, 2009, 03:05 |
Matthias Voß
Rep Power: 20 |
hi,
wich mesher do you use?? generally: make it a extruded 2D-mesh. with start / endfaces at the inlet/outlet of your modell. check out the manual on "Extruded Meshing". neewbie |
March 27, 2009, 06:24 |
Hi.
Thank you for the suggestion. I use CFX-mesh. I tried to follow the manual in CFX-help for the 2D Extruded meshing, but i got the following error message: "No boundary edge found. The surface may be highly curved dand mesh resolution may be poor. Try reducing the mesh spacing on the problem surface and retry (it is the my horizontal pipe that is marked red). As i can see my body and face spacings should be ok. I've used the inflation option and inlet/outlet as the extruded periodic pair (location 1 and 2). Under the Option tab in Tree viev i use "Delaunay" under Surface Meshing, "Full" under D Extrusion Option, a uniform distribution and I have changed the "Number of layers". |
March 27, 2009, 06:29 |
Matthias Voß
Rep Power: 20 |
hi,
cut your model by half. so you get a leading edge. that should work. |
Oscillating Flow in a Circular Pipe | Johann Ott | CFX | 3 | March 2, 2009 16:42 |
Tangential Air Flow in a circular pipe | Scott Turner | Main CFD Forum | 3 | January 31, 2005 14:59 |
flow in circular pipe | Jackie | Main CFD Forum | 1 | February 18, 2003 12:58 |
+ shape circular pipe - meshing possible? | Selina Tracy | Main CFD Forum | 2 | January 16, 2003 13:31 |
CREATING A VERTICAL CIRCULAR PIPE | sanjib das sharma | CFX | 15 | August 2, 2001 06:11 |
