CFX Mesh from Pro-e
Old   March 16, 2009, 12:35
Default CFX Mesh from Pro-e
Simulation Engineer is on a distinguished road
I am new to CFX and ANSYS. I am trying to generate a mesh from Pro-e geometry for use in CFX to perform analysis. Thus far - I have not found a method other that using iges from Pro-e for import into ANSYS - then writing the file for CFX using a .cdb file
Does anyone know of a better method? Perhaps using STEP file? I have access to ANYSYS Workbench, ANSYS, and ICEM as well as CFX.
Thanks in advance to all.
Simulation Engineer is offline   Reply With Quote
Old   March 16, 2009, 14:16
Default Re: CFX Mesh from Pro-e
LKF
LKF is on a distinguished road
I am not familiar with Pro-e, but if the option is available to save your model in parasolid format, you can import that directly into CFX-mesh.
Available for purchase from ANSYS is a bi-directional CAD connection as well. We're using that with SolidWorks and it works nicely.
LKF is offline   Reply With Quote
Old   March 17, 2009, 11:21
cfdguy's Avatar
cfdguy is on a distinguished road
LKF is right.
Go for Parasolid or purchase the plugin instead (recommended).
cfdguy is offline   Reply With Quote
Old   March 17, 2009, 20:22
Thanks for the tip about parasolid - I can create that format from Pro-e but do not see where you can import that directly into CFX. Could you tell me a bit more detail on the technique? Do you have to create a mesh in ANSYS - or am I missing something where the parasolid can be imported directly.
thanks again
Old   March 18, 2009, 06:28
LKF
The parasolid file can be imported directly into CFX-mesh (or one of other Workbench mesh utilities). You still need to generate a mesh and then import either a .gtm or .cmdb (mesh file) into CFX-Pre.
Create fine mesh that grows to coarse mesh (Urgent CZ FLUENT 1 January 3, 2009 10:36
Oscillatory mesh motion setup mesh flux ERROR jaswi OpenFOAM Running, Solving & CFD 5 August 23, 2007 04:41
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
dynamic mesh - structured or cooper mesh Manoj Kumar FLUENT 2 November 11, 2005 01:18
How to convert STAR mesh into FLUENT mesh ? Jihwan Siemens 8 November 10, 2004 04:11
