-   CFX (https://www.cfd-online.com/Forums/cfx/)
-   -   Activate vorticity (https://www.cfd-online.com/Forums/cfx/62875-activate-vorticity.html)
rikio March 22, 2009 22:31
Activate vorticity
Hi, all,
I want to activate Vorticity in CFX Post to help analysis. But problems came out.
An erroe message,
"CCLAPI::validateData - CCL validation failed with message:
Error: The essential parameter 'Option' is missing from /LIBRARY/VARIABLE:vorticity ",
displayed when I add the section below into Library.
VARIABLE: vorticity
Output to Postprocessor = Yes
END
Alternatively, I selected the variable Vorticity in output control. After 1 iteration, I run the CFX Post to visualize the vorticity contour. But an other error came out, which says,"DataReader::loadData - Error reading file 'D:\run_001.res': Error reading dataset G/COMMANDS"
Why these happened?
I know editing the VARIABLES file in the root directory is an efficient way, but I want to know why the two errors took place.
Please do me a favor to explain. Many thanks to all of you.
hamed1983 October 26, 2017 14:05
Hi
i have the same problem, plz let me know if you find a solution
rgrds
Lance October 27, 2017 04:07
Vorticity can be calculated in CFD-post, see Variables/Derived/Vortex Core/Velocity.Curl
hamed1983 October 27, 2017 10:58
1 Attachment(s)
Dear Lance,
Thanks for your reply. I did your comment and the result became like the attached. I want to know is it correct? or the vorticity should be reciprocal across the breadth of the ship?
Best Regards
