March 9, 2009, 07:16 |
asking for help: serious problem in CFX
we are running steady state transition modeling with auto timescale (timescale factor=1). however, as we change the timescale factor to 0.5, the transition location changed (as well as the pressure distribution). what's the reason for its change? in my understanding this factor only affect the convergence, but in our cases, we are sure the problem has converged? please, anybody have any comments on it? or any advice, please help.
many thanks littlelz |
March 9, 2009, 16:57 |
Re: asking for help: serious problem in CFX
Have you also done a mesh size sensitivity check? Also checked other tunable parameters (eg convergence residual)? If your simulation is not mesh converged then it does not surprise me you will get timestep sensitivity in a steady state simulation. Glenn Horrocks |
March 19, 2009, 11:50 |
Rep Power: 17 |
thanks, glenn
do you mean that the grid indpendence will cause such timescale sensitivity problem? because in my knowledge it is only mean the convergence problems. let's assume a simulation is converged fully, however the mesh is dependent (not refinement enough), will that cause such timescale sensitivity problem? please advice more info thanks again littlelz |
March 24, 2009, 04:29 |
Rep Power: 17 |
glenn is right, if you donīt have done a grid sensitive check (comparison of several resolutions), your solution in fact might be time scale sensitive.
March 24, 2009, 11:04 |
Confirm convergence
Rep Power: 18 |
What level of convergence did you acheive? What are the MAX and RMS residuals?
April 2, 2009, 08:54 |
Rep Power: 17 |
max residual 1e-4. is the goal.
in steady state simulation, the goal can't be met in any case in transient simulation, it can be met easily. then we compare the results from steady state and transient simulation, there is no difference at all. according to the CFX manual, our understading is the the local separation flow cause this local lack of tight max residual, which will not affect the overall simulation, so steady state simulation will be used |
April 2, 2009, 20:11 |
Rep Power: 143 |
Max residuals at 1e-4 is fairly loose convergence. The turbulence transition model is particularly prone to difficulties in convergence for steady state simulations as the separation point is often moving around and therefore requires a transient simulation for proper convergence. However, as you have found this small movement of the transition point often makes no significant difference to the key outputs (such as lift or drag). Whether this is the case for your model is up to you to determine, you have to do a sensitivity check on your model. Glenn Horrocks |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Problem in coupling CFX and Ansys for fluid-thermal sim. | Jordi | CFX | 21 | March 1, 2017 05:03 |
CFX 11 x64 solver? problem | Attesz | CFX | 6 | June 7, 2009 08:37 |
Fan Modelling Problem in CFX | Jenny | CFX | 8 | September 11, 2007 13:59 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
