2 domains - 2 physical timesteps? How to?
Old   March 30, 2009, 12:36
Default 2 domains - 2 physical timesteps? How to?
Craig Hildreth
flattie is on a distinguished road
I have 2 fluid domains with a solid between them. How can I set two different physical timesteps, without resorting to autotimestepping, which I don't want to use? The size of my domains is vastly different and the timescale needed to get the small domain to converge leads to very slow convergence on the large domain.
Thanks!
Craig Hildreth
flattie is offline   Reply With Quote
Old   March 30, 2009, 20:42
Rikio
rikio is on a distinguished road
Send a message via Skype™ to rikio
Local Timescale Factor can be used to set different timescales for different domains automatically. Please refer to section of "Steady State Time Scale Control" in HELP.
Wish it helps.
rikio is offline   Reply With Quote
Old   March 31, 2009, 11:31
Craig Hildreth
Thanks, but doesn't Localtimescale factor have a different timestep on an element basis rather than a domain one? I want to set the timestep for the domain as a whole.
Old   April 4, 2009, 20:44
stumpy is on a distinguished road
You can do this, but it's CCL only. Essentially copy the entire SOLVER CONTROL section and paste it under the DOMAIN section. Delete all the parameter except the timescale control parameters.
Mike
stumpy is offline   Reply With Quote
Old   April 5, 2009, 04:01
Rikio
Stumpy,
Does it work? I will have a try on this to check this "new" feature...hehe
Old   April 5, 2009, 19:27
Yeh, it works, I've used it before. You can do phase-specific timescales too in a similar way by pasting into the FLUID object of a domain. If you know how to read the RULES file (<install dir>/etc/RULES) you can see that SOLVER CONTROL is a valid child of a DOMAIN object.
[Gmsh] Version 20 of the bmshb file format to FOAM converter 7islands OpenFOAM Meshing & Mesh Conversion 36 February 9, 2019 22:47
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Multiple Solid Domains - Interfaces Scott CFX 8 July 31, 2008 15:20
multi fluid domains with differ. physical charact. John Walker CFX 5 April 15, 2006 22:32
Different physical mesh domains Juergen Almanstoetter (Almanstoetter) OpenFOAM Running, Solving & CFD 1 January 24, 2005 11:32
