FSI Simulation unsing ANSYS Multifield
Old   April 6, 2009, 04:25
Unhappy FSI Simulation unsing ANSYS Multifield
Fritzl
k_buz is on a distinguished road
Hello everyone
At the moment I'm busy doing my bachelor thesis. I'm trying to simulate a Fluid-Solid-Interaction of a helicopter blade.
As I am new to CFD I am probably not 100% aware of what im doing
I have the following setup:
The outer domain is a static domain which velocity is 0. inside is a dynamic domain which spins with 3000rev/min. in the smallest domain is the blade. The highlighted area is the fsi interface.
The goal would be to see the equilibrium position of the blade.
I have first tried to simulate it as a static structural problem. so the inputfile was set to be so. when i simulated it in cfx the blade wouldnt deform at all.
so i also tried to use a transient simulation using a dynamic simulation within the input file. but then this happend (it only calculated about 15mins, then an error came)
It looks as if the forces were much to high.
I am not sure about my settings at all: When using transient setup, the initial conditions must be set. for the rotating domain, I used 0m/s initial speed, but the domain motion under general settings I set to 3000rev/min. would that produce a step, which destroys the blade? or why did that happen?
actually I am not interested in the transient behaviour.. I'm only interested in the final position of the blade. Wouldn that be possible with a static structural simulation??
Please tell me if you need further information to help me
Thanks for your help..
k_buz is offline   Reply With Quote
Old   April 6, 2009, 16:55
Michael P. Owen
michael_owen is on a distinguished road
Have you run a steady state CFX model to get a better initial condition? The initial forces on the blade will be very high unless you do this.
michael_owen is offline   Reply With Quote
Old   April 6, 2009, 17:40
Fritzl
Could you explain what exactly you mean? I have tried to simulate it as a steady state and as a transient model. How do you mean "to get a better initial condition"?
fsi in ansys 11 kantored CFX 5 April 6, 2010 16:58
FSI TWO-WAY SIMULATION Smagmon CFX 1 March 6, 2009 13:24
FSI using Ansys LS-Dyna and CFX YY CFX 2 April 9, 2008 06:40
Restart of FSI simulation V. Kumar CFX 3 July 20, 2006 13:23
FSI using CFX and ANSYS Bi Chang CFX 2 May 10, 2005 04:47
