April 15, 2009, 03:40 |
Influence of including viscous dissipation
Michael
Rep Power: 17 |
Hi all
I am modelling a HVAC case including heat load from 150 people. Under the Heat Transfer I can include Viscous Dissipation which not has been activated for my simulations. My question is then if this not are incorrect and should be activated? Kind regards Michael |
April 15, 2009, 10:25 |
Pratik Mehta
Rep Power: 17 |
I do not think you need to activate that option for your application. |
April 15, 2009, 14:24 |
Michael
Rep Power: 17 |
Hi pratikmehta
thanks for your reply. I have run two simulataions one where it was activate and another where it was't. I could not see any difference in the result. So I think it will be ignore as you also think. kind regards michael |
April 15, 2009, 18:29 |
Rep Power: 143 |
You should try to understand what the buttons mean before you turn them on and off. Viscous dissipation in heat transfer is heat generation due to viscous action, like what you get with an oil film in strong shear. So yes, you can be confident for HVAC applications this is not a significant effect and can be left off. Glenn Horrocks |
viscous dissipation | swapnil | FLUENT | 1 | January 27, 2009 05:12 |
viscous dissipation modelling | mahjoob | FLUENT | 0 | January 31, 2007 18:52 |
temperature rise due to viscous dissipation | Marek | Main CFD Forum | 6 | December 30, 2004 16:24 |
VISCOUS heat dissipation | Joseph | CFX | 0 | October 1, 2004 08:52 |
Is the viscous dissipation term fully included? | yann | Phoenics | 0 | June 5, 2003 10:23 |
