April 13, 2009, 01:48 |
MODELING A ROTATING BLADE(pleas hehlp)
hamed
Rep Power: 17 |
HI THERE
is there any need to model the blade and the atmosphere together for analysing the act of TRANSMITTAL of material of atmosphere affected by the blade?! if yes should i define a solid domain for the blade and a fluid for the atmosphere? so how can i define the rotation of blade? i cant define rotation in solid domain?!!! |
April 13, 2009, 09:10 |
Fritzl
Rep Power: 17 |
You actually only need the fluiddomain where the blade is cut off. So in the middle of the domain the shape of the blade is missing. then you put a boundary condition "wall" to that boundary. then you can set up the domain as a rotating domain. so you actually let rotate the domain instead of the blade..
check out that post: http://www.cfd-online.com/Forums/cfx...ultifield.html |
April 13, 2009, 15:05 |
tanks alot
hamed
Rep Power: 17 |
i really appreciate
your favor u got the problem right. tanks alot |
Display Modes | |
IcoDyMFoam how to define more than one rotating regions | naoko_oyama | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 08:25 |
modeling two liquids flow over a rotating disk | fadhil | FLUENT | 3 | May 20, 2008 05:19 |
FSI on a Rotating Structural Model | drgolf | CFX | 9 | August 30, 2007 12:08 |
Difference b/t rotating wall and rotating domain? | Juno Kim | CFX | 2 | February 20, 2007 20:08 |
Modeling Flow/Saturation/Absorption in Fibers | Gene Dougherty | Main CFD Forum | 0 | June 6, 2003 14:49 |
