Vof in CFX ?
Hi All
is there any VOF module for sharp interface modeling in CFX ? if yes, witch method it use (PLIC or SLIC ....) "my mean is not only two phase model but exactly VOF and sharp interface modeling" |
CFX has a compressive differencing scheme for free surface simulations, but despite the rantings in the CFX advertising material it is far behind the free surface schemes in Fluent and other codes. You have to expect the interface to be smeared over several cells in CFX at best. CFX does not have SLIC or PLIC. Glenn Horrocks |
Depending on what the flow is doing, you're looking at a free surface 'thickness' of usually 1.5-2 mesh diagonals with CFX. So the only interface sharpening option available is refining the mesh... latslosh. |
A free surface of 1.5-2 mesh diagonals in my experience is only possible for a tightly converged simulation with fine time steps. If you loosen the convergence or use bigger timesteps to accelerate the simulation you will blur the surface more. Note surface tension makes free surface modelling significantly more complicated. Glenn Horrocks |
Tanks,
I saw some results of CFX that it can not save the sharp interface (for example in Slug flow modeling). In some manuals of CFX presented that CFX has VOF module, but I think it is not correct, VOF basically must save the sharp interface by spacially methods such as Youngs method. |
You should not generalise Ashgar. There is nothing "wrong" with the free surface modelling in CFX, it is just that it does not capture the interface as sharply as some other approaches. Whether this is a problem or not depends on the application. CFX has been successfully used on many free surface applications so you definitely would not say it is "wrong". Glenn Horrocks |
That is ok !
My mean was that the free surface model of CFX is not VOF and it make some mass diffusion that it may damage physically on results for some application, for example in wave modeling we don't have any mass diffusion between air and water, when CFX make a tin or tick layer of fluid with density of 500 between air with density of 1 and water with density of 1000 it is harmful for momentum eq. But when we have phisicaly some mixed condition in free surface it is so usfull. |
