Home > Forums > CFX
help about mesh deformation ?
Old   April 15, 2009, 04:38
Question help about mesh deformation ?
hmasenger's Avatar
hamed
hmasenger is on a distinguished road
hi everyone
i have successfully modeled a mixing tank and its rotating blade
but can u tell me
( how can i see the rotation of the rotating wall(blade) visible in cfx-post ?)
i mean i need to see how can i have that defined rotating wall animated in cfx-post?
all i have here (in cfx-post) is an stationary blade that has no motion and i am really confused!
should i define mesh deformation or something?
please tell me what do i need?
hmasenger is offline   Reply With Quote
Old   April 15, 2009, 06:31
Tassi
Tassi is on a distinguished road
Hi Hamed
You need to simulate the model as transient and then use the animation features to see the blade rotation.
BOL
Tassi
Tassi is offline   Reply With Quote
Old   April 15, 2009, 10:25
Unhappy
hmasenger's Avatar
hamed
hi tassi
u mean animation in ansys cfx pre? or in cfx-post?
how? can u explain a little more?
Old   April 15, 2009, 10:33
Question
hmasenger's Avatar
hamed
is there any need for mesh deformation ?
Old   April 15, 2009, 18:34
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
As hamed said - if the blade rotates it will be much better to simulate it using a rotating frame of reference rather than deforming mesh. Why are you using deforming mesh?
Old   April 16, 2009, 00:29
Tassi
Hi
No you wont have to use deforming mesh. Animation can be done in CFX-Post. Transient simulation and Animations are covered in CFX tutorials.
BOL
Old   April 16, 2009, 04:26
Unhappy
hmasenger's Avatar
hamed
Originally Posted by ghorrocks View Post
tanks for your reply
do u mean that i need to model the blade and the tank together and then define 2 domain?all i alredy have is a tank that the blade is cuted out of that and i defined a fluid domain so defined a rotating wall boundry
that contains the blade and a stationary wall boundry that contains the tank,s wall
can u explaine how can i have a rotating frame ?(i am new to cfx)
Old   April 16, 2009, 04:32
hmasenger's Avatar
hamed
here are some pic of what i have don to this tankalredy
Old   April 16, 2009, 08:24
Tassi
Hi
I guess you forgot to post the pics. There is a specific tutorial in CFX for you problem. That would help you immensly.
BOL
Old   April 16, 2009, 08:28
Can't see the images. Can you try posting them again?
Old   April 16, 2009, 12:49
Red face sorry!
  #11
hmasenger's Avatar
hamed
i have forgotten to send the pics link
so that it
http://www.flickr.com/photos/37458977@N04/?saved=1
i am waiting for your friendly guidence
by the way, i will be glad to have chat with u ,if you have time of course!
thous (hmasenger)is my yahoo id
thanks again!
Old   April 16, 2009, 12:52
Default pic
  #12
hmasenger's Avatar
hamed
tell if any more pic is needed for underestanding the situation
Old   April 16, 2009, 14:03
hmasenger's Avatar
hamed
Originally Posted by Tassi View Post
Hi
BOL
can u tell me wich tuterial is similar to my problem?
tanks for your atention t
Old   April 16, 2009, 18:19
Can you describe how it works? I assume the impeller rotates and the big tank is stationary. In that case cut a cylinder around the impeller and put the impeller in a rotating frame of reference, the tank in a stationary frame of reference. Connect them with a GGI.
Old   April 17, 2009, 07:21
hmasenger's Avatar
hamed
thanks a lot
i think i have got what you mean >>!
i modeled the problem again and solved that whit a rotating domain which is a cylender that the blade is cuted out of that but steal i cant see the motion in cfx-post
this is a tank which has a to plade impller that rotats whith speed of 15 rpm and i need to sudy the dissipation of water affected by the impller
here i have put the link of new pics and an animation
http://www.flickr.com/photos/37458977@N04/tags/rotating/
and i send a new thread in the forum take a look at that.
Old   April 17, 2009, 07:33
That's more like it. Have a look at the tutorial examples, especially the rotating frame of reference ones - there is a turbine one and might be some others (don't have CFX in front of me so can't be sure).
Also consider whether a frozen rotor approach is adequate for you. If it is it will save heaps of time. Otherwise a full transient rotor/stator is required and that can take ages.
Thread Tools
Trackbacks are On
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 05:49
CFX mesh deformation YY CFX 0 May 3, 2008 18:52
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
Mesh Refinement JY CD-adapco 7 September 19, 2002 13:37
