-   -   Tutorial 17: Unable to run the simulation (http://www.cfd-online.com/Forums/cfx/63692-tutorial-17-unable-run-simulation.html)
Mazen April 16, 2009 08:28
Dear all,
I would be most grateful if anyone could help me with this problem:
I am working on tutorial 17: Air conditioning simulation. I follow all the instructions in this tutorial, but when I start run the simulation I got error message (Error message number: 001100279) the message says: unable to find library winnt/TStat_Control.dll on path.........(my working directory). Then under problem report, the message says: “USER ROUTINE: Thermostat Routine could not be loaded. Please check the Library Path, Library Name and Calling Name. For FORTRAN user routines, the Calling Name should be in lower case”. I check the library path, library name and calling name (the calling name is in lower case) and everything seems ok. Note than I have copied the subroutine TStat_Control.F to my working directory. Also, I’d like you to know that I have Salford Fortran (FTN95) compiler installed in my PC.
Looking forward to hearing from you.
Best Regards :)
Mazen
Chilli83 April 16, 2009 08:49
I think that I once heard no space and that "-" is bad choice when giving names.
Michael
Mazen April 16, 2009 09:07
Hi Michael, Thanks for your reply. I am sorry I did not get your point! Would you please make it clear for me.
Regards
Mazen
Mazen April 16, 2009 10:53
Message has been deleated by Mazen
ghorrocks April 16, 2009 18:22
Chilli means that you should select a file name without special characters (-, _, & etc). Change the file name to TStatControl.F or something like that.
Also your fortran compiler is not the supported one. If you use a non-supported compiler then you can get weird errors so I recommend you change to the supported compiler.
Mazen April 17, 2009 07:34
Hi Glenn
Thanks for your reply and help. It means that when I copy the file (TStat_Control.F) from the ANSYS example, I paste it in my working directory without underscore (TStatControl.F). Another thing, would you please tell me which Fortran compiler should be installed in my system?
I appreciate your help in advance
Best wishes
Mazen
Mazen April 17, 2009 07:44
Regards
Mazen
Hi Michael
your point now is very clear and very helpful.
thank you
Best Regards
Mazen
rogbrito April 17, 2009 09:02
Hi Sir,
take a look on my simulation. Are you using Intel Fortran 9.0/9.1 as your FORTRAN compilar. Good lucky Sir.
http://www.4shared.com/file/72198900...tionpart1.html
http://www.4shared.com/file/72199871...tionpart2.html
With king regards,
Rogerio Fernandes Brito
Mazen April 17, 2009 12:22
Dear Rogerio,
Thank you so much for your support. Currently, Iím downloading your files.
Unfortunately, I am not using Intel Fortran 9.0/9.1. The one installed on my system is Salford Fortran (FTN95) compiler. Do I have to have the former one installed on my system in order to run the simulation?
Best wishes
Mazen
rogbrito April 17, 2009 20:15
h t t p : / / w w w . cfd-online . com / Forums/cfx/22898-cfx-10-user-routine-not-fortran.html#post77655
take a look!
