Home > Forums > CFX
stopping and re-starting moving mesh for static lift coefficients
Old   April 20, 2009, 05:19
Default stopping and re-starting moving mesh for static lift coefficients
Tim B
haconk is on a distinguished road
I'd like to calculate the static lift, moment and drag coefficients for various angles of incidence.
I created one model with a moving mesh but how do I make that transient model a stationary one within the run-time environment?
Or do I need to create individual models and do separate runs for each angle of incidence?
haconk is offline   Reply With Quote
Old   April 20, 2009, 18:42
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
Using moving mesh to do various AOA is a very complicated way of doing it. Just change the angle of incidence at the inlet boundary. If it is a simple steady case then use a simple steady model.
Old   April 21, 2009, 06:18
Tim B
Thanks Glenn,
I have a moving anyway for the transient runs, besides the model actually changes with various AOA (actively controlled), that's why I'd like to use the moving mesh method.
Just wondered whether I could obtain the stationary results by stopping and restarting the run and if so, how? Couldn't find anything in the manual re this.
Old   April 21, 2009, 07:16
You can't use moving mesh in steady state runs. Also I don't think you can move a mesh to a position and use that mesh for a steady state run.
You would only bother doing a moving mesh simulation of what you are doing if the flow timescales are similar to the wing motion timescales. If the wing is much slower than the air it can be accurately modelled as a series of steady state models at the various positions.
Old   April 27, 2009, 16:05
Tristan Burton
Tristan is on a distinguished road
We have done some moving mesh simulations to get "steady-state" port discharge coefficients as the ports are closed. Rather than generate a sequence of meshes and run them steady-state one at a time, we did a moving mesh transient simulation where the ports closed very slowly. In order to make sure our results were "steady-state", we did a 2nd run where it took twice as long to close the ports. A comparison of the two runs showed no difference between them until the ports were nearly closed.
I doubt that this was the most efficient way to solve the problem but it sounds like it might be an option for you.
Tristan
Tristan is offline   Reply With Quote
Thread Tools
Trackbacks are On
