-   -   Boiling of water with hot air (http://www.cfd-online.com/Forums/cfx/63826-boiling-water-hot-air.html)
Dr. Flow Squad April 21, 2009 05:46
I would like to work on a case including boiling of water. I have looked at the test example of boiling of water in the installation directory and it works fine for me and I understand it fully. It consist of "Water at 100C" and "Water Vapour at 100C".
Now I want to add a 3rd phase which is pure "air ideal gas". In my specific case I use the hot air to heat up water until it boils. The water enters a duct with hot air which make some of the water boil and form vapor.
But I cannot setup my case since I have 2 continuous phases. Is there a correct way to set up my case? please advice
br
Dr. Flow Squad
peterlee July 23, 2009 08:23
some question
2 Attachment(s)
Hi, does the boiling model in the installed directory really fill you?
I am searching for a well boiling model, but there are some problems!:(
one case, the water tempreture reaches 590k, and there have no water vapour!!!:confused:
another case, without heating, the water was boiling, and the curves are wrong!!!:confused:
So, I urgently need your help!
Dr. Flow Squad July 27, 2009 07:37
Sorry. Not much have happened since.
