April 9, 2019, 15:38 |
Dimpled chanel convergence
Marcin
Rep Power: 8 |
Hi everyone,
I want to make simulation of flow inside dimpled chanel. My problem is that it converge only for relatively low velocities(6-10)m/s. My solution does not converge if velocities are higher, i tried from range (30-40) m/s. Here are my bonduary conditions : Domain Default domain Air Ideal Gas Reference Pressure 1 atm, Heat Transfer THermal Energy Turbulence Model SST Wall function Automatic, Inlet Normal Speed, and Static Temperature Outlet:Static Pressure 0 atm, Dimpled Surface No slip wall, temperature 45 C, Vertical walls:Transation Periodicity, Rest of the geometry is treated as adiabatic no slip wall, I have no idea what is wrong, maybe my bonduary conditions are not appripriate, or Should change turbulence model? I would be grateful for any help. |
April 9, 2019, 18:37 |
Rep Power: 143 |
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
Rising residual behaviour and convergence | tjim | SU2 | 0 | October 12, 2018 04:04 |
In the case of convergence | aja1345 | FLUENT | 1 | July 31, 2015 03:58 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
