-   -   Jumps In hybrid Mesh (http://www.cfd-online.com/Forums/cfx/64312-jumps-hybrid-mesh.html)
realanony87 May 6, 2009 21:53
Hello Guys,
I have been testing out the simple TUBE hybrid hexa,tetra hybrid meshing tutorial in ICEM CFD.
I do a quick run in ansys CFX , and at the interfaces there appears to be a pressure jump at each mesh interface. The velocities seem fine though (although the boundaries are better with the hexa mesh)
Does anyone have experience with hybrid meshes? are they safe to use for more complex cases ?
ghorrocks May 7, 2009 19:00
Hybrid meshes are fine. You can get some apparent jumps at interfaces when the mesh is not fine enough. Also I assume you have all the pitch ratio stuff turned off - that can cause these effects.
realanony87 May 7, 2009 21:53
Do you mean pitch ratio of the hexa mesh at the interface ? So the ratio there should be 1 ?
realanony87 May 7, 2009 23:02
Roland R May 8, 2009 04:35
I think that if there is pressure jump at interface than hexa and tetra mesh don’t connect exactly at the interface. The nodes of interface 1 have to fit to the nodes at the interface 2. (1:1 connect) If the nodes don’t fit to each other than there is an interpolation at the interface, this can cause some inexactness. (The size of the inexactness = How many cells do connect to one cell at the interfaces?).
Roland
ghorrocks May 10, 2009 21:43
Pitch ratio is used in turbo machinery so blade rows with different numbers of blades can be modelled using periodic boundaries. That is a blade row with 100 blades can be connected to a row with 149 blades, where you are only modelling a single blade of each row. You use the pitch ratio to scale the flow across the interface to keep the relationship between the rows correct.
If you have pressure jumps at an interface then something is wrong. Is your solution properly converged? Is you mesh quality adequate? Have you got mesh size jumps at the interface?
