May 8, 2009, 06:42 |
unphysical solution near boundary
Tobias Krawuttke
Rep Power: 16 |
Hello!
My name is Tobias and I have a strange problem. I made a model of a duct with simple obstacles. fluid is iawps steam table. Boundary condition is static pressure@ outlet, mass flow rate with direction an total temperature @ inlet. the inlet is quite long with free slip walls and no significant change in the flow is estimated. Now, if I change the inlet temperature (increase 200K), the first node inside the model is not affected and there is a unphysical drop of temperature within the first cell. the residuals become very low anyway. the mesh is quite coarse at the inlet but i think that the boundary should not be affected. aspect ratio is ok and angle, too. I do not know why the solver "ignores" my new inlet temperature. Thank you very much for any idea. |
May 8, 2009, 11:06 |
Tobias Krawuttke
Rep Power: 16 |
The problem seems to be the steam table. If I choose another one built by myself with taskflow, everything is fine.
May 10, 2009, 23:34 |
Rep Power: 143 |
The IAPWS database makes convergence a bit trickier. Are you sure your table values are OK? Check you have not gone over the limits (min/max temperature, pressure etc) you have defined for you properties table. You might also need to put a few extra points in. Glenn Horrocks |
No results for solid domain | Gary Holland | CFX | 10 | March 13, 2009 03:30 |
Error near boundary layer as 1st grid decrease | CF | Main CFD Forum | 3 | October 3, 2007 10:21 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
Please help with flow around car modelling! | Tudor Miron | CFX | 17 | March 19, 2004 19:23 |
