-   -   Decending Temperature to Solid Domain (CHT). (http://www.cfd-online.com/Forums/cfx/64472-decending-temperature-solid-domain-cht.html)
sandeep_tu May 12, 2009 11:44
hi all,
i am trying to analyse the heat transfer between the solid and fluid domains (CHT), i,e there is solid domain and fluid is flowing through it and i am trying to calculate the heat transfer between them, i have a probem that i want to give the temperature for the solid domain as decending temperature (i,e high on the top and decreasing to bottom).
can any one help me that how can i do this, thanks in advance.
ghorrocks May 12, 2009 18:54
Define a CEL expression, maybe initial temperature = constant1 * (y/constant2 [m]). Make sure the units end up in temperature units hence constant2 has the units of metres.
You can also use 1D or 3D interpolation functions as CEL expressions.
